Originally posted by CatJo (AF160 OR AF200S for the ME Super
I don't know about your Vivitar flash- it might work the same way if setting shutter speed at 125/sec. but with these Pentax flash units, as well as several others of this era, they have their own meter for flash output. Then, all you have to know is the distance range for a set aperture and which ISO (ASA), as shown either on a graph on the back of the flash unit, or in the unit's little handbook. If you are within those distances, the metering sensor on the front of the flash unit will regulate output for good exposure. Some of those flash units have a +/- flash compensation control as we'll, but I don't think the AF 160 does.
You can even shoot in M mode for a low light shot, metering for ambient lighting without the flash, which would mean a slower shutter speed, and the Flash units meter will work for fill.
I just found my little handbook for the very compact AF 160 flash, and by golly it does show a graphic scale on the rear of the flash unit for distances, etc. My favorite flash unit from that era is the AF 280T which is still quite compact, but features a tilt/swivel head for bounce, and even a downward tilt for close work.
