Originally posted by dlhawes The FA 100 f/2.8 is a terrific lens, though it's got the SMC motor that seems to have caused a lot of trouble. Mine's working great, knock on wood.
The FA 100 f2.8 has a screw drive focus system using an in body motor not an in lens motor ( as does the F and DA version including the WR version.) There are no Pentax branded macro lenses with any other type of focus system.
SMC is a coating on the lens elements. Did you mix this up with SDM? SDM is the silent motor system used in some lenses. The early SDM was prone to failure, the newer versions not so much.
