Originally posted by WondringLisa To clear things up, I meant micro. I forgot there was an intermediate size sd card at one point. I think I'm going to get some regular SD cards once I can afford it.
I can understand the argument about the additional physical contact point being a potential issue, which is partly what I'm asking Samsung and Sandisk about, but what happens when you try to use the micro card in your computer: format it, and read/write to it? After copying off your photos, of course. Or are you saying you can't copy your photos? Does the camera still read and write this card seemingly properly? Can you transfer the files via wifi if you can't in some other way?
I've never had a problem with an sd card of any size except the three full-size cards that all physically broke (the plastic around the fingers broken in all three cases) and the one micro card that found its way into the garbage disposal, but if I did have a problem that reformatting didn't fix, I'd try to find the $10 for a new card. I did have one case of odd behavior, but that card worked fine after formatting with the Tuxera formatter.
If you have your purchase receipt it's likely that your micro card may still be covered by a warranty, so you might also be able to get a new, probably better card, for the price of a postage stamp. Both manufacturers replaced my three broken cards immediately when I mailed them back.
