I'm afraid I passed on the DA 16-85mm lens. But I cannot imagine the same part number would be reused if it were not the same! I guess stranger things have happened! Yes, the old FA 28-200mm was a rebadged Tamron, with some differences, perhaps in the hood also. Historically, this old lens was the first ever zoom lens going out to 200mm that could focus at the closer distance this one can. What is stranger to me is the APS-C equivalent is off enough to make me question that the hoods should be the same. The most critical would be the wide end of 16mm being like 24mm on FF, not 28mm. My DA 18-135mm is much more like the FA 28-200mm FF model in its angle of view, but does not take a 72mm filter size- it is much smaller and takes a smaller hood.
I just checked a photo of the DA 16-85mm with its hood on, and you are right- it does not look the same. And I see no marks on it for guidance in mounting the hood. My old hood appears to be deeper along the top. I measure exactly 2 inches from the tip along the top to where it fits against the camera body. It also does not have PENTAX printed on it. so perhaps my hood is also a Tamron clone, although I do know the lens coatings are different. Evidently the opening is the same, as the OP says the hood obtained fits onto the lens but the flanges do not engage. Could be a flange design difference. If that is true, having the same part number is indeed a mistake, and why? At least put a -B after the number!
