Astrophotography and auto-exposure seldom work. It looks like the camera's light meter took one look at the mostly black sky and used a very long shutter speed in a vain attempt to make the picture middle gray. Manual exposure is a must for situations like this and not so hard because the moon's brightness is extremely predictable.
The moon's surface is always in full sun with no clouds. In theory, the
Sunny f/16 Rule would work except that the moon's surface material is quite dark. (The human eye is fooled into thinking the moon is bright white due to the contrast with the dark night sky).
Anyway, the rule for exposure of the moon is known as the
Looney f/11 rule. Your telescope has an f/4.9 aperture which becomes an f/9.8 aperture with the 2X Barlow lens which is so close to f/11 that it does not matter.
Solution for your telescope with the 2X Barlow:
* Set the exposure mode to M
* Set the ISO to 100
* Set the shutter speed to 1/100
* Take the picture
* Review the picture on the camera's display (zooming to check the quality)
* If the Moon is too dark or too bright, adjust the shutter speed accordingly
