Originally posted by mjp29 ok, so one simply can't do it with the k-r.
Some of what you typed confuses me, as I don't see how the camera can "stop down" or force a picture to be taken at max aperture, with a manual lens, where I control the aperture with the aperture ring.
The aperture is overly complicated because it evolved and each advance retained some backward compatibility.
I want to start with the K-mount to save typing. (Before that is a whole different story.) The original K-mount cameras had a simple arm to push the aperture lever on the lens. The arm only has two positions. The first position opens the lens aperture fully. That makes it easier to frame and focus. The second position releases the spring-loaded lever to allow the aperture to close. The aperture ring on the lens controls how much the lens stops down. The camera arm stays in the first position normally. When you press the shutter button, the arm goes to the second position. The second position is also used if your camera had a depth of field preview switch.
Mechanically the K and M lenses are the same. The original cameras also had another arm that fit into a groove on the lens mount. A tab on the lens moves with the aperture ring, so the camera's meter can tell where the aperture ring is.
Everything is awesome new technology for a few years but then the world decides it would be cool for various reasons if the camera body could have full control over the lens aperture. The K-mount is only a few years old so users would be annoyed if Pentax orphaned those new lenses, so the system has to be compatible. The solution was to redesign the camera arm to be way more complicated. Now it can move in many small precise increments between the previous two positions. Those precise movements can move the blades precisely. The A-series lenses had to be designed to translate that movement accurately into stops, which was not important earlier. The camera needed more information about each lens so the lenses had a set of electrical contacts to tell the camera what their aperture range was.
At this point (early 80s), the camera's arm that followed the aperture ring position was only necessary for backward compatibility with K or M lenses. When those lenses were used, the new camera body worked exactly like an original K-mount body. When new A-series lenses were used, the new cameras could control the aperture with the precise arm. That allows more program automation and better metering. Program modes didn't work with the K or M lenses.
When autofocus became a thing, Pentax changed the way the electrical contacts were used (F-series). All the lens information was now sent to the body through a data pin. More lens information can be sent to the camera. The A-series system had no way to handle variable aperture zooms or lenses whose wide open aperture was on the third-stop scale. The Pentax-A* 135mm f1.8 can only tell the camera that its maximum aperture is f1.7.
Pentax started leaving the aperture ring detection arm off some cheaper cameras, nicknamed the crippled mount. That's when K or M lenses became harder to use.
That was the state of things when Pentax started designing DSLRs. They released the first model, the *ist D, with the crippled mount and no K/M lens compatibility. A firmware upgrade allowed the green button to tell the arm to turn back into an on-off switch, which is enough to use those lenses. This is a compromise and only works in M mode. The other modes don't work because they need more information about the lens, and the camera doesn't want to guess.
So if you use a K or M lens on a Pentax DSLR, the camera's arm only works in two positions, like the original K-mount. The camera doesn't know any lens information so metering is not "live". There's a compromise to meter with the green button, which moves the arm and measures the light. The camera also moves the arm in that on-off way when you shoot. The metering switches out of matrix metering to center weighted. The flash switches to fire at full power. The central AF point is active to indicate sharp focus.
A few new lenses have a fully electronic aperture, so no more levers. But they won't work on the K-r.
There's some indication that the K-3 iii will improve on this system. It'll be interesting to see how.
