Originally posted by gump I will have to test this as I have one Watson in my battery rotation. My experience is that the first frame will be dark (seriously underexposed) not black. What would cause this?
When the solenoid fails, it starts like that.
Black it never is! Just seriously underexposed up to almost black.
If you adjust brightness or similar with Adobe PS then you can see a little bit more of the original photo, but of course in terrible quality.
Originally posted by The Squirrel Mafia Sad to say that Ricoh didn't really do anything about that issue other than what seems to be a very tiny modification to the solenoid, but it still fails on some K-70 cameras.
One can put it like this, but:
- Solenoid failures went right down under the 2% failure rate which is normal and every manufacturer has something like that.
- Of this 2% failure rate of course not all are failed solenoids but even it it would be so:
Lucky he, who owns a Pentax which fails like this!
Because if you'd own Canikon or Sofu you'd be bust, no chance for DIY repair!
