Originally posted by fancyqtr
The camera packages I saw were Canon and Nikon and came with the standard lens, 70-300 lens, 2x lens extension (not sure what that is called), wide angle lens, filters, and verious accessories including the bag and tripod. They started at $699 and went up from there. I just really can't afford them.
Perhaps not related to the battery issue but in case you do consider one of those packages:
standard lens? An 18-55 something most likely. OK
70-300 - also OK
2x extension - doubles the focal length of your lens. Which sounds great but is (IMHO) useless on either of those lenses because it will degrade the image quality and reduce the light
wide angle lens - this is most likely not a real 'lens' but a filter that screws on the front. Do yourself a favor and throw it away.
various accessories - in my experience junk that doesn't deserve the time and waste of material to make them
bag and tripod - bag might be OK if you don't have one. The tripod will most likely be barely strong enough to support a cell phone.
---------- Post added 02-03-21 at 05:50 PM ----------
Your K-100D is 6mp.
A quick check on auction site shows:
k-r - 12mp for roughly $200 -300 often with lens
k-5 - 16mp for roughly $350 - 500 often with lens
And you can use your existing lenses as well.
