Originally posted by brbob1 with PK tether.
You don't need PK tether any more.
Create a text file containing the line [OPEN_DEBUG_MENU]
Name the file MODSET.??? where the ??? is correct for your camera (see below)
copy the file to the root directory ( highest level on the card, ie. not in a folder)
turn the camera on with either the card door open or the appropriate button pressed (see below)
scroll down the debug menu to LENS ROM DAT CAMERA=>SD (NOTE
CAMERA=>SD)
press ok
Turn the camera off. The file LENSEEP.LNS should now be on the SD card. This is the file you need to edit then put back using the above steps but selecting LENS ROM DAT SD=>CAMERA instead.
Note 1, I don't have the details of editing the LENSEEP.LNS file handy at the moment.
Note 2, I've only used the K7 to do the conversion but just checked the Kx and it extracts the LENSEEP.LNS file.
Camera modsets:
Km (v1.10) in the form of the file name is MODSET.464, Switch on while pressing the "Delete" button
K2000 (v1.10) in the form of the file name is MODSET.482, Switch on while pressing the "Delete" button
Kx (v1.03) in the form of filenames MODSET.492, Switch on while pressing the "Exposure correction button (+/-)" button
K10D (v1.10) in the form of filenames MODSET.421, Switch on with the card door open
K10D (v1.20-v1.30) in the form of filenames MODSET.TXT, Switch on with the card door open
GX10 (v1.10) in the form of filenames MODSET.429 Switch on with the card door open
GX10 (v1.20-v1.30) in the form of filenames MODSET.TXT Switch on with the card door open
GX20 (v1.01, v1.03) in the form of filenames MODSET.454 Switch on with the card door open
K20D (v1.03) in the form of filenames MODSET.442 Switch on with the card door open
K200D (v1.00.00.03) in the form of filenames MODSET.445 Switch on with the card door open
K7 (v1.01) in the form of filenames MODSET.474 Switch on with the card door open
