Originally posted by photogem That's the one I use in my PC since a while, never had problems except when I unmount the SD-card the prober way and plug it back in,
it won't be found,
I guess I have never done that...
Soooooo...I went upstairs to that computer with a couple of SD cards and gave it a try and had no problem with the following sequences:
- insert --> eject --> insert same again
- insert --> eject --> insert same again --> eject --> insert different
In both cases, the cards mounted just fine after the ejects. I should probably mention that the computer is running Win
8 7 sp1 with the original drivers that shipped with the reader. Rosewill has an updated driver pack that includes Win 10. I should also note that Windows reports the individual reader slots as removable media devices with assigned drive letters. The media is unmounted on eject, but resources remain allocated.
I have had very good luck with Rosewill computer/IT stuff.
