Originally posted by Sidney Porter Nothing that I am aware of has changed. The camera has not left the house, hot shoe cover on. The camera has not even been used much the KP gets used most of the time
OK...so why is the camera suspect?
When you said the flash would not fire, did you mean no P-TTL, no X-sync (flash in manual mode), or something else? If "flash ready" does not show in the viewfinder and top/back LCD (means no dedicated flash/device detected*), the X-sync should still work at shutter speeds at or below 1/180s.
I suspect something subtle is causing this. I usually don't suggest a general reset, but it might be helpful to try doing so on the flash.
* "Flash ready" is a legacy feature that uses the right rear contact. If that contact is masked, the camera will not show flash ready and will ignore the "digital" contact such that automated features are not possible. See
http://kmp.pentaxians.eu/technology/hot-shoe/ for shoe contact mappings.
