Originally posted by Wasp Unfortunately, they are way too big. You can cut or grind them down to size. There is a thread about it here somewhere. It is not for the faint of heart from what I have seen.
The tricky part is to have a tab so that you fit it the right way up every time. There might be issues with the thickness as well.
If you fit a split image screen, you will find that spot metering no longer works.
Thanks, that will save me a trip into the loft. Been trying to clean my K3 focus screen but have a tiny little hair on the bottom right that I can't remove. Perhaps it might be on the prism, the sensor is clean as a whistle tho.
Tim
