1 Day Ago   #1
Alnjpn's Avatar
Ricoh GR freezing
My old Ricoh GR appears to have developed a problem. When I start it after it has been off for a while it freezes open. If I take the battery out and put it back it seems to reset itself and then works fine. It continues to work ok until it is off for an hour or more and then the problem returns.
I have replaced the battery, cleaned the contacts, and tried different cards but the problem is still there. This is the original GR with the 5.01 firmware update.
Anything else I can try or is my trusty GR on its way out?
1 Day Ago   #2
Is it the 8mp gr digital? If so, there's a common issue where grime gets in the adj wheel and it causes the camera to freeze. More frequent use and wiping gently with alcohol has helped in my experience.
1 Day Ago   #3
Alnjpn's Avatar
Thanks, this is the 16mp Ricoh GR released 2013/14 time
battery, camera, gr, pentax help, photography, ricoh, ricoh gr, troubleshooting
Lifespan of ricoh gr / gr II / gr III - how long do/did you have your ricoh? lunarwitch Ricoh GR 11 11-20-2019 12:36 PM
ERROR Ricoh Theta software freezing up + not converting pdonah1 Ricoh Theta 360 Cameras 2 04-30-2019 04:16 AM
Order Your Ricoh GR / GR II! Adam Ricoh GR 5 04-23-2019 07:35 PM
All times are GMT -7. The time now is 04:12 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
