11-21-2008, 08:13 AM   #1
K10D won't accept Pentax-M 135mm prime lens
Help! I just purchased a Pentax-M 135mm 1:3.5 prime lens on ebay and I can't get it to work on either my K10D or K100D camera bodies. When I attach the lens to my K10D, I get a flashing "F-" and when I attach it to my K100D, I get a falshing "Av". Any idea what I need to do to get the lens to work?
11-21-2008, 08:17 AM   #2
You need to enable the A setting in the custom menu.
I forgot exactly which custom menu it's under but it should be called "Allow A ring to be used" or something like that.
-Yale
11-21-2008, 08:36 AM   #3
Wheatfield's Avatar
QuoteOriginally posted by jdpenk100d Quote
I'd start by reading the owners manual.
11-21-2008, 08:56 AM   #4
Shaloot!'s Avatar
Yea you have to allow it to read the lens. Its in the custom menu and enables you to use the aperture ring. even after that you will see the "f--" and to meter you press the green button and it will give you a shutter speed. i keep it on M mode when i use these lenses.
double check the manual as well.
11-21-2008, 09:26 AM   #5
THANKS GUYS! This solves my problem!
K10D menu --> Custom setting --> "using aperture ring" --> permitted
11-21-2008, 11:00 AM   #6
Marc Sabatella's Avatar
This is on of the all-time most frequently asked questions here. There is a *great* thread on the ins and outs of using manual lenses:
K100D (Super) Pictorial guide to using manual lenses [imgs]: Pentax SLR Talk Forum: Digital Photography Review
11-21-2008, 12:09 PM   #7
thanks, I'll check it out.
11-21-2008, 03:48 PM   #8
Moderator PEG Judges
Kerrowdown's Avatar
You guys are quick, I knew that answer, hell I don't know many, but well pipped to the reply.
02-19-2009, 02:34 PM   #9
can I use "Av" mode to shoot if i use pentax M series lens? Does the camera give a correct shuttle speed?
i do not often use "M" mode.
Thank you!
02-19-2009, 02:37 PM   #10
Mike Cash's Avatar
QuoteOriginally posted by trna Quote
Thank you!
Only if you shoot with the aperture wide open. For anything else you have to use "M" mode.
02-19-2009, 02:45 PM   #11
thank you.
which means, i have to use f3.5 if i use Av mode?
since my K200D has green button, i will use "M" mode anyway.
02-19-2009, 05:42 PM   #12
thank you.
Actually, regardless of what you do with aperture ring, the camera ignores it and shoots at f/3.5 anyhow when you shoot in Av mode. Which can sometimes be useful - in low light, that's probably what you would have done anyhow. But if you wish to use any other aperture, you need M mode. And indeed, the Green button (AE-L on models that lack a Green button) makes M mode a snap.
135mm, camera, k100d, k10d, lens, pentax help, pentax-m, photography
Help! K10D doesn't accept my 135-600mm F6.8 baby fiathriel Pentax SLR Lens Discussion 18 06-18-2013 07:21 PM
For Sale - Sold: SMC Pentax-M 135mm f3.5 Prime Lens (US) aerodynamics Sold Items 6 10-25-2010 11:55 AM
For Sale - Sold: Takumar Bayonet 135mm f2.5 Prime Lens Low Price Youngster Sold Items 1 09-24-2009 11:18 PM
Ooops, won 2 135mm m42 lens, which one should I keep? reknelb Pentax SLR Lens Discussion 2 02-25-2007 11:12 AM
My new/old lens: Tokina 135mm f/2.8 prime superfuzzy Pentax SLR Lens Discussion 7 02-16-2007 09:42 PM
All times are GMT -7. The time now is 09:54 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
