Originally posted by CountryGirl @ 35mmfilmfan - I do believe it is a center spot diffuser -- not particularly exciting -- and it measures about 49mm. Short of breaking the glass on another filter and gluing the diffuser into it (and hoping to get it absolutely plumb), I don't see mechanically how to fit it into something else. Retaining ring? Do the two threaded pieces that hold the colored glass screw into each other?
---------- Post added 04-18-21 at 08:13 PM ----------
@Denver Yes, I tossed it. Just wanted to be sure I wasn't overlooking something.
Yes, with many filters, the actual filter itself is held inside the mount by a threaded retaining ring, on the 'female' (no gender issues intended or specified !) side of the filter mount. There are often two diametrically opposed slots or indentations in this ring - they can, with care, accept the pointed ends of geometry set calipers or dividers, and the ring unscrewed. A lens spanner should also do the trick, should you have one sitting around somewhere. I too feel it is a centre spot diffuser, but the surround to the spot looks more clearly defined and opaque than others I have seen.
