Originally posted by Not a Number Make sure you have the K-3 bin file and not the file for K-3ii.
The bin file should be fwdc220b.bin and not fwdc230b.bin.
Try holding down the menu button with no cards in the camera. This should give you a blank screen with the current installed firmware version.
With a card with fwdc220b.bin file in the root folder in slot one leave the card slot door open while pressing the menu button and powering on the system. The camera has a fail-safe mode that won't allow updates if the battery is below a certain level.
How old or used is your battery? An old battery even "fully" charged may not have enough detected capacity for the camera to allow the update.
Desperation time - reset to factory defaults. This last resort will undo your customizations - I'm not sure if it will clear your User Mode settings - it may.
Thanks, the file is fwdc220b-2.bin. The battery is from 2013, but it shows a full level and I can shoot all day with it. The camera won't turn on when the SD door is open whether there's a card in slot #1 or not. I currently have version 1.21 running and the camera is working fine so I think I'll just leave ut unless a cure can be found.
---------- Post added 04-23-21 at 06:30 PM ----------
Originally posted by Kwong the filename should be fwdc220b.bin Not sure why you have a -2 in there. Maybe try rename the file. Size shoud be 16,444 KB
Thanks for noting that. I deleted the -2 and it worked. The strange part is that I downloaded the file from the Pentax site again to make sure that I hadn't accidentally added the "-2" and that's the way it came from the Pentax site. Any way, once I fixed the name the update procedure worked. Thanks to you and everyone else for their help.
---------- Post added 04-23-21 at 06:35 PM ----------
Originally posted by pjv As you are a new member, please forgive me for asking what appear to be obvious questions.
Problems in the past have been because of some of the below issues.
Are you trying to update your K-3 to version 1.42, and if so, what version is currently displayed?
Have you only transferred the bin file to your SD card?
Have you inadvertently downloaded the K-3 II firmware?
The camera will only go to the firmware download page when it recognizes the update on the card when turning on with the on/menu button combo is used.
Hi, it turns out that when I download the 1.42 version from Pentax to my mMac, it adds "-2" to the file name. Once I removed that the update procedure worked perfectly. Thanks for your help.
