04-23-2021, 04:23 PM   #1
OK, WB, Brightness, etc Buttons Not Working
I was out doing some moon pictures last night, and noticed that after I switched from timed to single shot, using the button above the OK button on my K-1, suddenly I couldnít shift out of that mode any longer using the shortcut. In fact, in viewfinder mode, none of the buttons around the OK button, and the OK button itself, are working. When I do live view, I can change my shot and my white balance etc., but when I do the viewfinder, all those buttons are acting as if they are disabled. When I go into the menus to adjust anything, it works just fine. This feels like a software issue, but I cannot tell why it would suddenly start happening. Iíve taken the batteries out for a moment and also used the reset option in the menu. Any ideas?
04-23-2021, 04:35 PM   #2
QuoteOriginally posted by jawats Quote
Also happened to me once but could never figure out why hasnt happened since
04-23-2021, 04:38 PM   #3
QuoteOriginally posted by Kwong Quote
Did yours start working normally again after awhile?
04-23-2021, 05:01 PM   #4
Lowell Goudge's Avatar
Hit the function button above the 4 way controller, it toggles between different info screens. My K1 MKII is set to have the 4 way controller options in one info screen and af point selection in the other
04-23-2021, 06:02 PM   #5
Learned something new. Didn't know one could do that.
04-23-2021, 06:08 PM   #6
yes and never happened again
04-23-2021, 06:35 PM   #7
The toggle worked, but as soon as I made a selection, the AF point selection came back and the function options vanished. Iíd love if they stayed so I didnít have to hit the function to bring them up each time. Is there a way to make the functions the default?
---------- Post added 04-23-21 at 06:37 PM ----------
Oh, and thank you for the help! I omitted that in my prior reply.
04-23-2021, 06:48 PM   #8
QuoteOriginally posted by DWS1 Quote
It took me a year to figure that one out, donít feel too embarrassed
04-24-2021, 05:30 AM   #9
Kevin B123's Avatar
It's the C20 type 2 setting to have AF default and the you press the function button above to use the other functions. Really handy, since you want af most of the time and the other functions are locked out.
04-24-2021, 11:16 AM   #10
Crooski's Avatar
Remove AF Active area from select and the four-way controller will work as it was before
04-25-2021, 05:01 AM   #11
Youíre right
It would be preferable to have it go back to the selection screen, but .... it doesnít
However there are risks in both options, I have found myself failing to get focus only to discover that I have advertantly moved the focus point by accidental use contact of the 4 way controller, probably during review of past images, but I have also had the converse of accidentally changing the color options in JPEG, or WB on my K5 and K1 when it is set on the normal 4way controller settings.
af, button, buttons, camera, controller, function, function button, info, k1, mode, options, pentax help, photography, screen, selection, shot, troubleshooting, viewfinder
Illumination of buttons - not working for me GeeEmm Pentax K-1 & K-1 II 6 03-15-2021 03:22 AM
GRIII Macro and WB buttons not customizable Carlos_gr Ricoh GR 4 02-25-2020 11:29 AM
When camera is in "AF Active Area Select" how to use ISO, Flash, WB, timer buttons? Newtophotos Pentax DSLR Discussion 5 10-12-2015 06:23 AM
K-x tungsten WB is not a fixed WB kxr4trids Pentax DSLR Discussion 3 05-18-2010 12:43 AM
K-7's auto-WB vs. Lightroom's auto-WB inferno10 Post Your Photos! 13 07-16-2009 08:54 AM
All times are GMT -7. The time now is 02:51 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
