Does anyone have an idea what is going on here? I bought a Pentax S2 Super - it seems to be in great condition. I shot a first test film and most images are great - but just a handful have a purple artefact insuring from one edge. Here are the worst three examples (and most images are fine). All were taken with the 55mm Auto Takumar, however one of them also had extension tubes attached. The lighting for the three pictures are very different.
I also uploaded a couple of negatives that show this effect continues over the sprocket holes and is in a different position along the edge on one image compared to the others.
Any ideas/opinions about the cause?
- It is an old, out of date C41 film - so maybe it was a film problem?
- It was lab processed, but maybe there was a processing problem?
- I don't think it is lens flare, given the lighting of the different images.
- I wondered if it happened when removing the lens (I only had one lens plus the extension tubes at the time, but was exploring a new camera).
- Or is there a light leak (in which case why does the position vary?)
I've put a brand new film in the camera now, and have two additional lenses to try, so it will be interesting to see if the problems recur this time, but I thought I would see if anyone has any ideas before I shoot too much of the film! Thanks for you opinions.
