Originally posted by gofour3 Welcome to the forum!
What lens are you using, and what apertures did you use on the above pictures? If you are shooting wide open on a 6x7, your DOF is very narrow.
Phil.
Phil,
Thank you for your observation. I have a Takumar 105mm, and was, in fact, shooting most of these images wide-open, at f/2.4. Although I understand that having the lens wide-open might be the culprit for some unintentional off-focus, I suspect something else could be the issue.
When I attempt to focus on infinity, everything is slightly blurry, except for certain objects closer to me. Oddly, when I photograph these objects that are in focus, they come back totally back-focused.
And yes, unfortunately, the problem does not lay within a diopter lens corrector...
Thank you so much for all the kind comments, I sincerely appreciate it!
Best,
J.
---------- Post added 04-29-21 at 07:43 AM ----------
Originally posted by ProfessorBuzz Phil's right on. Also, have you verified if there is a diopter correcting lens at the viewfinder - that may also be an issue.
You'll find the DOF is very pronounced.
One way to deal with this is set up a row of identical objects receding, and then use the lens distance scale.
Shoot this a few times, starting at about f/16 and open up the aperture. Then develop and check the results.
Very smart.
I might try that last suggestion of yours!
Thanks
---------- Post added 04-29-21 at 07:45 AM ----------
Originally posted by Aaron28 distance or beyond the subject seem in focus.......another thing that crossed my mind is the pressure plate set for 120??
Aaron,
Thank you so much for the help. The pressure plate was set to 120, but that was something I hadn't thought of, so thank you so much for bringing it up!
