Originally posted by BarryE Yup, Bob, that's along the lines I was concluding. The battery's marked so if it happens again it'll be more conclusive. I suppose I could swap out the pair of SD cards too, which will narrow it down further.
Time will tell ...
Good luck for the monitoring if the fault reappears. Hopefully not.
Like many others already said for themselves, I have several genuine Pentax batteries and I rotate them in three bodies (K1, K-3, K5). The two oldest are 2011 and 2012 models, still working fine and lasting for so many shots I don't worry about it at all.
So it may have been a random kind of fault? You'll see if it happens again and again ... or if not, and then you can conclude better. Hope for the best!
