Originally posted by santinowuzhere I'm currently using it on a Praktica LTL, but plan on eventually using it with my Spotmatic SP.
Mainly, I'm afraid of accidentally damaging the lens by messing with a switch that I'm unfamiliar with.
Leave the switch on A for both your Praktica and future SP cameras. The only use case for M is with Bellows or extension rings or when adapted to other mounts. In fact, it is best practice with SMC/S-M-C lenses to leave it on A almost all the time. The only time it is safe to move it from A to M is when the small interlock pin on the lens' mount face is depressed, such as by a rear lens cap, a mount adapter, bellows, other similar. Moving from M to A is always safe. Never force the A/M switch.
Camera cautions:
Don't move the switch when mounted to the SP F, SP ES, SP ESII, or Electro Spotmatic. Those models do not depress the interlock pin.
Some non-Pentax cameras have screws on the mount face that may foul the interlock pin on SMC/S-M-C lenses. Removal of the lens if fouled may be difficult in the extreme. Your Praktica has a smooth mount and poses no risk. (Just tested on my LTL 3...
