05-10-2021, 09:43 AM   #1
Pentax 67 door has some play after snapping shut
Hello all, I purchased a Pentax 67 in overall what seems to be in great shape (a couple rolls are currently being developed which will tell for sure). One thing that the seller warned of is that the light seals will eventually need to be replaced, and indeed they seem a bit rough. But, not clear whether it is actually a problem at the moment.
Anyway, I've discovered that when I close the film door, it satisfyingly "snaps" shut -- but then there is still some play if I squeeze the door close more -- it can squeeze in another mm but then it sort of springs back into its resting position.
Anyone ever encounter this? Is it a problem? Maybe it's just the rim squeezing against the foam light seals?
I'm within my 30 day return window so I'm just trying to be as meticulous as possible in identifying any potential issues.
05-10-2021, 12:26 PM - 1 Like   #2
QuoteOriginally posted by aeraym Quote
...Anyway, I've discovered that when I close the film door, it satisfyingly "snaps" shut -- but then there is still some play if I squeeze the door close more -- it can squeeze in another mm but then it sort of springs back into its resting position.
Congratulations on your new gear.
My two Pentax 6x7/67 both exhibit the same characteristic with their film doors. More movement at the latch end than the hinge side.
05-10-2021, 02:33 PM   #3
OK! This is a relief. At least doesn't point to any major flaw. Thank you for the info.
camera, door, light, pentax, pentax help, photography, play, seals, troubleshooting
Nature Lady Snapping Turtle joelbolden Post Your Photos! 8 04-28-2021 05:15 PM
Battery Compartment Door is Stuck shut on my ist PentaxBirdLady Repairs and Warranty Service 15 02-10-2018 08:57 AM
Looks like Nikon has shut down the "1" line (link) IchabodCrane Canon, Nikon, Sony, and Other Camera Brands 36 09-06-2016 05:52 PM
Misc back door, front door - lorikeets & Rouletts Cee Cee Post Your Photos! 12 03-21-2013 10:55 PM
K100 has premature 'Low Battery Indication/ shut down" seriousam Pentax DSLR Discussion 19 07-09-2007 08:36 AM
All times are GMT -7. The time now is 04:45 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
