Originally posted by Bertrand3000 That means that mechanically your lens is fine. If you don't get F-- then the electronic part cannot be fried either. I am at a loss of what is happening here.
While the "A" contact "gates" both aperture control, all it means is that the mount contacts are not evaluated unless the "A" contact is detected. Evaluation of the contacts will result in aperture control (no F--) enabled at minimum, but is no guarantee that AF is also functional.
I am pretty sure that most (all?) Pentax lenses having no aperture ring have the "A" contact hard-wired as "present/on". I can't say for sure for the DA 35/2.4, but as a prime, it is likely that the mount mapping for aperture range and minimum aperture are also hard-wired. The only contact with an absolute requirement for electronics is the "data pin", which for an AF prime is required for sharing that an AF lens is mounted and for coordination of AF function.
As for the OP...a refund is probably in order.
