Originally posted by Pentaxnewbie1991 Do third party lenses causes so many issues
Almost all makers include cautionary notes regarding other than their own brand lenses, batteries, accessories, and flash. A few example of why come immediately to mind...
- Vintage lenses having the unsafe variants of the "Ricoh pin" may be difficult to remove should the "pin" foul the AF drive screw. Collateral damage to the camera is possible during the removal.
- Some adapted M42 lenses may foul and abrade the power contacts in the mirror box with their aperture actuator pins.
- Third-party batteries represent several potential risks, particularly if used with in-camera charging. Ditto the above for third-party AC adapters.
- Improper fittings for microphone, headphone, remote release, power, data all have potential for damage and one can find help requests on this site as evidence that it does happen.
- Put that high-voltage Vivitar flash that worked great on your ME Super film camera on the hot shoe of your dSLR and with any luck the camera will do a recoverable lock-up and shutdown. Without luck, there may be smoke.
All of the above being noted, most of us here own and use an assemblage of non-Pentax lenses, batteries, accessories, and flash. I use hot shoe accessories from Yongnuo (radio triggers and flash) and Sigma (P-TTL flash), batteries from Watson and Wasabi, an AC adapter from HQRP , Bowen wired intervalometer, Yongnuo radio remote shutter release, and literally dozens of non-Pentax lenses, including my main walk-around Sigma 17-70.
To lessen risk, buy new from reputable dealers and ask questions if unsure. Most recent name-brand products advertised as Pentax compatible will be quite safe with the possible exception of non-Pentax M42 lens adapters where caution is always appropriate.
(...some of my lenses are labeled in Cyrillic...
