Originally posted by Lowell Goudge IS will or should work on all zoom lenses in the F and FA range.
A lenses do not communicate anything really, they have a fixed coding of minimum and maximum aperture. but that is all. for an A lens you need to enter the focal length yourself, and for zooms this will be a compromise you can pick minimum focal length, the meadian focal length, or if you intend to shoot at a fixed focal length set it to that value.
I shoot with old zoom lenses in the past, and that's what I did too: enter a middle value between min and max zoom focal lengths.
But I am going to buy a generic zoom which I will use in darker situations, and would like it to have the IS working correctly at any zoom.
I already own a Sigma 17-70 2.8/4.0, which communicates its focal length stepwise to the camera, and the camera IS works accordingly.
Is anything similar possible on older zooms? Does a FA type zoom, for example, tell the camera its actual focal length (not the range)? And a F, an A, an M zoom?
This is what I would like to know before deciding which zoom to buy.
