Originally posted by suynem It is running frimware 1.21.
Ok. The good news is that you already have a lot of firmware updates on your camera. If you avoid the lenses detailed in the later updates you should not have a problem using and enjoying your camera.
Changes to V1.42
Optimized focus operation for new lenses HD PENTAX-FA 31 mm F1.8 Limited, HD PENTAX-FA 43 mm F1.9 Limited, HD PENTAX-FA 77 mm F1.8 Limited lenses and smc PENTAX-FA 31mm F1.8AL limited, smc PENTAX-FA 43mm F1.9AL limited and smc PENTAX-FA 77mm F1.8AL limited lenses.
*Contents of [Version 1.41] and earlier version will be also updated.
Changes to V1.41
Optimized performance when attaching new lens HD PENTAX-D FA*85mmF1.4ED SDM AW.
*Contents of [Version 1.40] and earlier version will be also updated.
Changes to V1.40
Optimized performance when attaching new lens HD PENTAX-D FA*50mmF1.4 SDM AW.
Improved stability for general performance.
*Contents of [Version 1.30] and earlier version will be also updated.
Changes to V1.30
Corresponded to [KAF4 lens mount] that is equipped with an electromagnetic diaphragm control system.
Enable new lens HD PENTAX-DA 55-300mmF4.5-6.3ED PLM WR RE to shoot stable by updating firmware.
