Hi All.
I'm looking for a solution to my damaged 100mm DAW macro f2.8. The very thin thin flange where filters screw in was damaged so much so that a lens cover barely holds on and often falls off. I sent it to Precision for a repair, but they quoted me a price that was 90% of the cost of the lens new so I can't justify a repair (I was pretty miffed actually at the quoted price for what seems to be a simple repair). Anyway, optically the lens is still great. I've seen other 'lens hoodies' but they all seem to fit larger diameter lenses, not a 49mm lens. I could use rubber band to hold something on, but that's less than desirable. I was hoping the collective Pentax experience here might have an answer.
Thanks in advance.
DJS
