Originally posted by Thundershot Low light performance is ideal, but I understand I can't get everything with my budget. I would like to stake out birds at dusk and dawn if my camera permits though.
Used KP (great build quality for years of use, great imaging including low light with high ISO performance) with the DA 55-300mm PLM lens new. You will get very high quality, fast and accurate autofocus, (AF), and there are bound to be some lightly-used pre-owned KP offerings turning up maybe right here in the marketplace, or in Amazon Canada, or in one of Canada's premium camera marketers, because of the recent arrival of the new Pentax K-3 III. Some KP owners might be selling theirs to get this new $2,000 USD camera. The DA 55-300mm has an advantage over a longer telephoto lens at times, because it offers the shorter 55mm also. You can crop your image afterwards to get the same resultant image size as if you had used a longer lens than 300mm, but if your lens is too long you cannot expand 1/2 bird into a full bird afterwards. So this lens is more versatile. You might not always need that much telephoto in all circumstances.
Since you are totally new to photography, after getting your equipment, just keep in touch with us for pointers. When You first get your camera, do avoid setting the exposure mode dial on "Auto" which disables many controls and disallows many adjustments, but instead use the "P" (Program) setting which is likewise for fully automated exposure by the camera, but will allow the user to access controls and adjustments. It will also allow access to the exclusive Pentax Hyper System, which is a super-fast system of user-controlled override during the automated shooting to make virtually instant adjustments on the fly. No other manufacturer has anything like this.
You will have a lot to learn, and a top-quality Pentax DSLR, the newer the model, the better, is a wonderful tool! You are in a great environment to learn in, and it will be fun. The KP is of top-quality with a very durable build and outstanding low light performance, yet relatively compact. It can deliver great results, even right out of the camera with no post-processing. This will let you concentrate on just learning photography.
