Originally posted by stevebrot The default is to use the program line, though I don't have a clue how that would work out in M mode for bracketing.
My K-3 is set for Tv shift.
Just tried in M mode, K-1 does aperture bracketing. Don't know why bracketing works at all in M mode. Manual and bracketing would seem contradictory. I guess Pentax had to choose some sort of default rather than reset the drive mode when setting the camera to M mode.
To force the camera to do only shutter speed bracketing, one way is to set it in Av mode, choose an aperture, and choose an ISO (disable auto-ISO, using ISO + rear dial). Then, the camera can only change the shutter speed when bracketing.
You can also use P mode and do the same operations, but be sure not to touch the front dial (shutter speed), otherwise the camera will do aperture bracketing instead.
If you want to reset ISO, use ISO + green button. This is one of the least intuitive things on Pentax cameras, IMO. You cannot set auto-ISO when setting the top custom function dial to ISO, and using the top value dial.
If you use a P-TTL flash, all bets are off. Bracketing will then be done only with flash exposure compensation. And the flash may not even have time to recharge. Bug in the camera, IMO.
