05-26-2021, 12:29 PM   #1
Burst rate with my KP and a DA*60-250 vs A* 300 f/2.8
Hello,
Some weeks ago I was birding with the two below configurations:
KP in AFC mode, RAW, max burst rate, ISO auto, TAV mode set at f/5,6 & 1/650s, DA* 60-250 + 1.4 converter, autofocus
KP in AFC mode, RAW, max burst rate, ISO auto, TAV mode set at f/5,6 & 1/650s, A* 300 + 1.4 converter, manual focus
In both cases, I did not reach the buffer limit for RAW;
In both cases, AF was on spot (for the A* it is not a choice);
For the DA*, FPS priority was selected
What I noticed: the burst rate with the A* was better, although I did not try measuring it (no means to do that).
Do you think this is possible and what could be the reason? Or is it perhaps only a “feeling” from me that would be dismissed if a rigorous test was done?
Thanks
05-26-2021, 12:38 PM - 2 Likes   #2
Otis Memorial Pentaxian
QuoteOriginally posted by scc Quote
Manual focus?
05-26-2021, 12:55 PM - 1 Like   #3
The burst rate would be higher because there will be no breaks to re-focus with the 300mm.
05-26-2021, 02:31 PM   #4
How many shots did you take in the longest burst?
05-26-2021, 02:58 PM   #5
swanlefitte's Avatar
If the bursts were long enough you can get a more or less accurate time by looking at the exif time of first and last shot which is measured to the closest second.
Yet here it says you get af shutter lag of 0.089 sec in af and 0.083 in manual.
Pentax KP Review - Performance
05-27-2021, 02:20 AM   #6
Fogel70's Avatar
I believe it is because the camera is a little processor limited. With more things to do between each frame, it takes a little longer to be performed.
Even though you are using FPS priority, the processor has to do AF calculations and send AF commands between each frame. Which puts a little more demand on the processor than if using manual focus.
05-27-2021, 07:41 AM   #7
scc
QuoteOriginally posted by zzaletel Quote
I took between 3 ans 4 shots when noticing this difference.
---------- Post added 05-27-21 at 04:43 PM ----------
QuoteOriginally posted by swanlefitte Quote
Thanks, I will look at the exit information.
05-27-2021, 11:31 AM   #8
scc
Unfortunately I did not take sufficient frames in one burst to draw any conclusion from the exifs. I should at least take 7 or 8 frame to do that. I notice that my technique in birding lacks frames, I have the tendency to stop shooting after 3 frames.
05-27-2021, 02:42 PM   #9
You would probably need about 10 bursts of at least 4 secs averaged together before you could get a decent estimate.
06-03-2021, 07:57 AM   #10
ehrwien's Avatar
You said you're shooting RAW, and I think most (if not all) of the "picture correction settings" (highlight/shadow protection, horizon correction, noise reduction) only apply when shooting JPG, but I'm not sure about AA filter simulator... isn't a JPG with the chosen settings being embedded in the RAW file, though? All of those actions take some time, so turning them off might get you closer to the maximum burst rate the camera is capable of?
06-03-2021, 09:40 AM   #11
scc
AA filter simulator is off in the menu. Actually, even in JPG, most of the correction options are off. The setting are as follows:
Highlight correction auto
Shadow correction auto
Noise reduction high ISO is on low correction
Shake reduction is on
All other corrections are off. Normally, the RAW setting should ignore the above settings except the SR.
af, afc, burst, burst rate, camera, converter, da*, da*60-250 vs a*, exit, information, iso, kp, manual, mode, pentax, pentax help, performance, photography, rate, review, shots, thanks, time, troubleshooting
DA* 60-250 owners: How do you carry your 60-250 at the ready? apisto Pentax SLR Lens Discussion 25 12-30-2017 01:49 PM
K-5 vs MZ-S vs LX vs PZ-1p vs ist*D vs K10D vs K20D vs K-7 vs....... Steelski Pentax K-5 & K-5 II 2 06-28-2017 04:59 PM
Battery type/voltage and K-50 burst rate jswilson64 Pentax DSLR Discussion 6 12-21-2016 05:02 PM
"55-300 on 300/f8" vs "60-250 on 250/f5.6" snimcho Pentax SLR Lens Discussion 35 06-25-2015 01:33 AM
For Sale - Sold: Trade my DA*60-250 for a DA*300 (or maybe an F/FA*300) (Worldwide) dgaies Sold Items 6 02-08-2011 07:46 PM
All times are GMT -7. The time now is 05:40 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
