Originally posted by Simon K What a relief, I felt a bit like a desperado when downloading it ;-)
Nothing wrong with the procedure as you described, nonetheless somehow you'd managed to get rid of the sRGB space along the way. So good luck finding the leakage.
Edit: I may have misunderstood; you uploaded it again, NOW with sRGB assigned. I can't see it though, your most recent upload visible for me is tagged 2 hours ago.
OK,
Since you seem as interested as myself in the line of questioning.
I just sent a test photo. photo is a shot of the sand & water
Original RAW : Export from Lightroom settings are....JPG.....small.....90%......all metadata........Output Sharpening: (Screen)......amount: (standard)......Color Space: sRGB. and thank you Peter for those settings. ends up 1.3 MB
---------- Post added 06-03-21 at 06:31 AM ----------
Originally posted by UncleVanya Another thought, hosting images externally on something like Flickr allows you to post links here which can be higher resolution if desired.
That sounds interesting.
Is there any problem getting to the exterior storage file from the upload button on the Gallery site?
---------- Post added 06-03-21 at 06:40 AM ----------
Originally posted by Apet-Sure Just saw your eagle shots in the 'post your photos' section. The EXIF data shows jpeg quality at 85%. If you can get the height down to 800 pix I think jpeg quality will stay at 100%. At least, that's been my experience.
where can I make an adjustment with the pix height?
Not sure I even know what that means, but I'm sure I need to know.
