Originally posted by RICHARD L. I dismounted the lens from the K1 body and I found one of the two little copper-colored electrical contacts on the bottom of the lens mount was out of place. No more AF ... I put the contact back into place delicately with small "watch repair" tools, remounted the lens on the K1 and the AF resumed working normally again.
Man, these electrical contacts seem flimsy, mainly when you take into account the cost of this lens. This small metal tab will probably break off soon and I'll have to go see my trusted local repairman to have it replaced.
For real, they should make these costly DFA* lenses "indestructible".
This kind of problem is why I hesitate to buy an expensive lens like this one. The same goes for the new K-3 Mark III. I know that you mostly read about the problems with camera's, lenses and so on, but I also find, however low the numbers, that I never read that Ricoh solved a problem even after the warranty expired. And Pentax as an independent company with their own repair service tried to solve problems, which they never do nowadays it seems. It is due to the extended warranty in my part of the world, European Union, that I sometimes buy a Pentax item. But I miss the service of old.
I currently own some of the indestructible ones, they are from the 70's and 80's, they are m's, a's and f's.
