2 Days Ago   #1
gump's Avatar
KP wanted to shoot PEF
Using my relatively new KP I took some shots of our new vehicle and much to my surprise when I downloaded them they were PEF files. I check my shots from a few days ago and they were also PEF, I had not noticed. Went back another shoot and they were DNG which is what I have always used. I did not change this in the MENU. It is possible I inadvertently hit a button or combination of buttons. I am still getting used to the KP layout. Any thoughts why DNG would change to PEF or default to PEF without using the menu?
2 Days Ago   #2
UncleVanya's Avatar
QuoteOriginally posted by gump Quote
Did you apply firmware updates between those sessions? Typically it doesn’t change the settings but it has happened to me once in a while.
2 Days Ago   #3
gump's Avatar
NO
No, I have yet to do the recent firmware.
2 Days Ago   #4
3by2's Avatar
Funny enough I've done this but still don't know how I did it and I just had a fiddle again after reading this thread. Same as you, I took some pef's without knowing, except in my case LR 5.7 couldn't read them and alerted me on import, otherwise I might not have noticed.
So no help from me on an answer as to how but at least you're not alone.
2 Days Ago   #5
AlwaysAl's Avatar
I did this once, can't remember which Pentax model but simply stated, I had inadvertently hit the "reset" function in the menu. A surprise but was able to change it back to my "normal" and hasn't happended since. Chalked it up to just being part of the learning process.
2 Days Ago   #6
I had that specific case of RAW format being automatically changed from DNG to PEF with the K1. It was related to using a certain camera mode or video and going back to stills mode, something like that, with RAW format not reverting to DNG automatically.
2 Days Ago   #7
gump's Avatar
You probably touched FX1 and then you can temporarily take pictures in another file format. See page 48 of the manual. Hope this helps!
Read more at: KP wanted to shoot PEF - PentaxForums.com
I just tried the FX1 button and it did not change the format. I may have inadvertently turned on "movie" in changing settings but I have never shot video with the camera. I will play with that and see. This started as I was checking out a newly repaired lens, Sigma 17-50. I would not believe that could have an affect but this stuff is all magic to me as i was raised in the mechanical age.
2 Days Ago   #8
dlhawes's Avatar
I wonder whether switching "custom drive modes" could cause that effect, if one had set one to dng and forgot to set the others to dng, those others would still be taking the default.
2 Days Ago   #9
gump's Avatar
QuoteOriginally posted by dlhawes Quote
Although I have not used the camera extensively I have used the most of the programable functions with out this happening. I just ran some "movie" tests and the DNG format did not change.
2 Days Ago   #10
Somethings like multiexposures, or timelapse, or something, I don't remember what mode did the switch to PEF, but I remember well that I could reproduce the behavior.
2 Days Ago - 1 Like   #11
gump's Avatar
I keep it simple. Being from the film era and never having an overabundance of money, I still tend to take time to set up a shot and aside from fooling with exposure bracketing I do not use the "finer" points, use manual mode, back button focus, and manual focus if necessary. I will try to watch for it to happen again and if it does i will post. Thanks for your interest.
1 Day Ago   #12
Paul the Sunman's Avatar
Were you using a User Mode that may have had PEF selected?
1 Day Ago   #13
Otis Memorial Pentaxian
This is something that happens most commonly with the control panel (info button) or as an accidental inclusion to a User mode. DNG PEF is the default, but once changed, it should stay that way, unless part of a saved User mode.
camera, change, dng, kp, menu, pef, pentax help, photography, shoot, shots, troubleshooting
Unable to view PEF DNG from KP 7.62lew Troubleshooting and Beginner Help 33 12-13-2019 05:58 AM
KP vs K-70 - to KP or not to KP, that is the question OldChE Pentax DSLR Discussion 28 11-02-2019 05:29 AM
KP bug or KP Broken, Av Mode and Red Blinky Warning Text in LV BruceBanner Pentax KP 26 06-25-2019 05:06 PM
Question Selling to a buyer who lists a wanted item in the Wanted Items forum fwcetus Site Suggestions and Help 11 08-22-2015 08:10 PM
K5 pef files must not be the same as K5 ll pef Applianceguy Pentax K-5 & K-5 II 20 09-17-2013 09:14 AM
All times are GMT -7. The time now is 04:16 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
