Originally posted by Larrymc I ran into a similar problem with DCU 5.9.2 yesterday. The DCU browser would load the DNGs properly but when an individual image was clicked part of the screen was a gray rectangle. I shut DCU down then tried to reopen it and DCU crashed with the Win10 message that there was a problem and DCU was shutting down. I tried to reopen DCU several times and same problem. I then did a complete uninstall of DCU and reloaded the original program .exe file from the Mk III every thing worked fine, downloaded the update and reloaded it and same crash. I am back to the original DCU 5.9.1 program less update and things are working well......So Far.
I'm wondering if the original executable from the Mk III was a 32 bit file or a 64 bit file? The update I used was a 64 bit file, but things worked fine last week......Hmmmmm?
My usual RAW developer is DXO PhotoLab and I'm waiting for them to produce the Mk III profile and having to work with DCU in the meantime.
DCU v5.9.2 is not without it's problems.
I've found the need to go to the 'Window' tab and choose 'Default Layout' to rectify the "loss" of the 'Folders' sub-window. This, of course, puts everything back to "normal", not as I want it across two screens. Provided I don't try to move the 'Folders' sub-window I can work with it.
I did log the problem with Ricoh UK Support but got a reply that there was nothing further that could be done (or words to that effect) and the case was closed.
The DCU v5.9.2 download is a .zip containing both 32-bit and 64-bit installers. I don't remember for certain but I seem to remember the v5.9.1 software within the camera is also dual-format. I've certainly got it installed (and updated) on both 32-bit and 64-bit machines.
Looking forward to v5.9.3
