Originally posted by AfterPentax Mark II Originally posted by photogem The DA55-300PLM if focused manually has the focus-ring not at the front but its back right after the bajonet.
If the K-70 is correctly set to MF, then one should be able to focus by turning this ring!
The PLM is a focus by wire. So the electronics in the lens must work, otherwise you cannot use MF.
Yes, I am aware, I have and like that lens.
I tested it today (for the first time body set to MF) on my KP and K30 prior writing this message:
On both bodies I was able to focus manually and take photos. OPV + LV.
No focus confirmation though.
The 55-300PLK also kind of works on NON-KAF4-Pentax bodies, but only wide open.
