Originally posted by Silent Street If your camera has the MLU function (sliding nib on left side of mirror box, viewed from the front), this should be taped over to stop it from activating when the camera is stored in a pack and transported. If it is jarred through movement, the mirror will flip up and will flatten the battery. When this occurs, a reset of the mirror is required, v.i.z., firstly install a new battery. With a wooden toothpick or pointed match (do not use anything metallic), insert it into the reset hole left front of camera (again, viewed from the front) and press once. Then press the shutter button once, and wind-on. This being the standard and effective mirror reset operation, the mirror should thus reset to its normal position. If it does not, a bigger problem exists somewhere.
DO NOT SUBJECT THE CAMERA TO BANGING OR RAPPING ANYWHERE on the assumption that will fix a problem you are not familiar with. This brutal action (I've hard of worse!) could well damage the winding mechanism.
I tried changing the battery and also tried resetting the MLU all of which to no avail. Plus the crunchy feeling in the winding mechanism when the film is loaded is a very big indicator of some other mechanical issue going on. I was taken aback by the fact that it happened right in the middle of a roll? Which was super confusing. I hadn't had any issues with the MLU before and I almost always store it in the same way in the same bag. However, after a little bit of poking around I finally decided to contact the store I purchased it from. They mentioned that it might be worth it to get the camera CLA-ed by a technician and that should resolve the issues. So ultimately I ended up sending it out to be looked at/repaired hopefully. You're absolutely right about knocking it on something. I had used the heel of my hand to sort of and it did knock the mirror back down but after that I stopped and got really concerned about the crunchy feeling.
Hopefully the technician will give me some good news once he has a chance to look it over. Crossing my fingers! I will let yall know though! Could be helpful for other searches.
