Originally posted by Bob 256 Have you tried HDR shooting? There are two ways to do it with the K-1. The first way is to use the HDR mode (top adjustment dial) with RAW capture. You can let the camera make an HDR rendition (ADV is probably the best one) but a better way is to use RT to separate the three exposures and then import them into an HDR program such as Photomatix. Like RT, you can go crazy with the adjustments Photomatix allows so it will be a learning curve unto its own.
The second way is to simply use the bracketing feature of the K-1 which shoots several (in most cases, I use 3) exposures sequentially. Then you import those into [photomatix] and do your thing.
Using K-1 HDR creates a single file with all exposure variations in it while bracketing creates separate files - the choice is up to you, however if you use the K-1 HDR to create a JPEG, the camera does the HDR work and you end up with a single JPEG file which can't be broken into the individual exposures used to make it.
In any case, this might be a solution to retaining the reds and keeping black scale rendition in your high contrast shots without making the compromise of underexposing the entire shot (actually at least one of your composite exposures will be underexposed).
Just another option on the learning road.
@Bob256 sorry for going over things again but I haven't worked out where fully to post things in the forum yet and as this is on topic of your suggestion I wanted to share it!!
The last few days I went totally HDR and explored the realm. I've got a package called LuminanceHDR:
Luminance HDR
and another one called HDRMerge:
HDRMerge
What I've done is this: the Samyang (Rokinon) 24mm F1.4 lens finally arrived recently so all shots have been done using this lens. I set my focus and exposure points first, then bracketed with 3 shots at 0EV, -2EV, +2EV. The results I then merged using both above mentioned packages.
HDRMerge, I find gives quite ordinary and boring results. The output can be set to DNG but there are no settings to play with. The resulting file can then be tweaked in RawTherapee which I have done and got great results with.
LuminanceHDR is a little different. There are many different computational algorithms used and settings to adjust. I found a guide online and followed the procedure using two algorithms then blending them together in GIMP. The results are similar to HDRMerge.
However, I found that using the first algorithm in the list and then shifting the pre/post gama settings and post saturation can yield very extreme and dramatic results.
The full folder is here which contains a mixture of different shots, HDR and non-HDR:
Update your browser to use Google Drive, Docs, Sheets, Sites, Slides, and Forms - Google Drive Help
I am really proud of this one! I set the K1 on top of my AV Rack using ISO 100, F8 (if memory serves me well) and shutter of 1sec. I used the 3 shot bracket described above and blended. I needed to restore the curtain at the rear as it went funny but here is the result:
HDR_Blend_6-2-restore.jpg - Google Drive
It is really intense and dramatic. I am really happy with it!!
Over time, I am trying new things and adding to this album. Perhaps I should include it in my signature or something?? I have also re-ignited my Instagram feed too with many K1 images
I hope the pics will be enjoyed by many
