Originally posted by slartibartfast01 If Pentax specify an operating temperature range then the camera should work reliably in that range. It shouldn't only work if you don't use live view. Operating temperature is ambient temperature not internal temperature.
This is too simplistic a view. A black camera left in the sun for an hour on a 100°f day will probably develop an internal temperature of upwards of 140°f. Leave the same camera in the shade on the same day and the internal temperature will change very little. And that is with the camera off.
Turn the camera on and start using liveview/ video and tge heating will be a lot more.
I wonder if the design parameter to keep the camera as thin as possible might make it a bit more prone to heating up. The heat sink on the sensor might not be as thick or able to dissipate heat as easily.
If the KP has an articulated screen, it will dissipate sensor heat a lot more easily.
