Originally posted by erikro Hi fellows.
On my K-1 II I can fine tune the autofocus for my DA300mm and DA300mm + 1.4TC and it gives different results. OK
But on my K-3III there is no difference whether I have 1.4TC or not.
Then I use DA300mm alone, it's OK, but if I put 1.4TC on, the pictures are out of focus!
If I adjust the focus so that it fits with 1.4TC, the pictures will be fine, but if I take 1.4TC off, fine tuning does not fit on the DA300mm.
It's the same with my DFA 150-450mm.
It seems like the camera can not see that I have a TC mounted.
Have others observed this?
I raised this on the Pentax Euro site and had a reply this morning:-
"Customer Support [2021-09-09 12:52:35.437]
Thank you for contacting Ricoh Imaging.
This problem has been identified and is currently being investigated and expect to be fixed in a subsequent firmware update.
We hope we were able to help you.
Let us know if you have any further questions.
Your reference number is:PRI-20210729-0012"
Just await the firmware update now!
