Originally posted by Michael Piziak So, let me get this straight. With bellows, one has to first turn the aperture ring to take a reading, 2nd is to take a reading (with an M lens) by pressing the green button, then third turn the aperture ring back to the first setting, then fourth to push the shutter button to take the pic. My question is, why is there a need for step 3 - why can't one just leave the aperture ring setting from step one remaining on the lens?
I understand the part about having to use the green button in M mode - thanks!
What I do is compose with the lens wide open, then stop it down to the shooting aperture and take a meter reading. Using the green button method, you may be done, take a picture and see.
The metering range of these cameras can be a bit limited, so sometimes the combination of the small lens aperture and the bellows extension can put the meter out of it's range, in which case the chosen shutter speed may not be optimal.
Consequently, sometimes it's compose and focus, stop the lens down, take a meter reading and set the shutter speed (the green button combines this into one user operation), take the picture, chimp, rinse and repeat.
I tend to make fairly heavy use of the histogram when I'm shooting with a bellows as that is what tells me if everything is correct regarding the exposure.
Quote:
Thanks for your reply. I understand all of it. I also agree that, especially in photography, that simplified (or over simplified) terms/definitions can lead to confusion. Seems like some times, or even often times, a single word or short phrase can have more than one definition/meaning....
Sometimes, when you ask a person what time it is, they will tell you how to build a clock. On the surface it may seem helpful, but in reality it isn't answering the question, and may just overcomplicate things.
There is a fine line between giving not enough information and giving too much information. Too much information can lead to confusion, causing more questions, which can lead to more confusion.
Imagine asking what time it is, being told how to build a clock, asking for some clarification and being told how to build an atomic clock.
This is why I try to keep explanations fairly simple. It's easier to provide clarification on a simple answer than to walk back a complicated one.
The mechanics of photography really isn't all that difficult.
One thing you will want to look into at some point if you are serious about extreme macro photography is focus stacking.
Securing adequate depth of field is very often a problem in macro, especially when using a bellows where magnification ratios are often greater than 1:1 (the object is smaller in real life than it is on the sensor/ film).
The image below is a focus stack shot with the K1, Pentax Auto Bellows and a Fujinon 90mm enlarger lens.. The flowers are under 1 cm across.
