Originally posted by DeKay Forget all that, when doing multiple long exposure shooting it better to set C2 - 12. Interval Shooting Options to 2. Standby Interval.
Then setting Standby Interval to Minimum in the Interval shooting options.
Now it will take the next shot once the previous shot and all its processing has finished. This way you don't get any missed frames.
Thanks for pointing that out, I'd missed that feature!
With the newer Pentax cameras having so many configurable options it's not difficult to miss the odd parameter when it's a feature I use rarely
---------- Post added 08-05-21 at 02:31 AM ----------
Originally posted by cometguy Please explain how the battery is used to hold the aperture at f/4 in such a case... I presume that you're talking about lenses without aperture rings? But even still, in cameras with all-electronic aperture settings only (no mechanical aperture rings), you're saying that some large amount of battery power is needed to hold the aperture at any closed-down f/-stop?
As I see it, the aperture defaults to wide open, even with the camera off so no power is applied.
When an exposure is being made "something" closes the aperture to the required level, holds it there, then re-opens it at the end.
These activities require power, which, on a modern camera, is supplied by the battery and not by a set of springs, cams and gears which are pre-loaded by the photographer's thumb via the film-wind lever.
So whether it's a "large" amount of power or not, it'll be a contributory factor and will add up over several hundred shots.
If one's got the interest, time and resources, it might be instructive to set up a camera with a fully charged battery and a "normal" KA or KAF lens set at say, f/8 on the camera body, and run a test to ascertain how many 15sec manual focus exposures can be made before the battery runs out, then, having recharged the battery, re-run the test with the lens set wide open … even possibly re-run the test again with a fully manual K or even M42 lens. All of these tests would obviously need to be run by the same person using the same camera and battery to have any relevance.
I use a lot of old manual K, KA and M42 lenses. I'd always put down any apparent increase in battery life (and it can be noticeable) to not having used the autofocus, but maybe the aperture activation is a contributory factor as well!
Not sure I'm THAT interested to run the tests myself, but I'd look forward to any results should anyone bother
