Originally posted by handlep Can anyone illuminate me please?
Nice pun
Take some images and check if it is working correctly.
When using optical triggering in P-TTL mode, the on-camera flash will be firing at least twice....once to trigger the slave to make a pre-flash; and once to trigger the slave to fire for the main flash. In Master mode it will be firing a third time to contribute to the flash output.
You are correct that in Controller mode it should not be contributing to the flash output. You should not be able to see this by looking in a mirror as the cameras mirror will be up at this point. It may be that in Controller mode the output is brighter for the first two functions, because it does not need to save any power for the main flash. Optical triggering depends on line of sight between the two units and in a bright ambient situation you want as much power from the controller flash as possible.
