Originally posted by ShutterPro Have you experienced something similar?
Yeah, more than one with K3 and DFA100wr and DA*55.
Open every compartment, face it down and "gently" blow it with hair dryer until it dry. Don't use high-heat. Don't blow directly into the lens mouth! You just want to dry up the outer shell on this step.
Next, close every compartment and sink the camera into a bowl of rice, leave it there about 24 hours and test it. I did leave battery door open but no rice in it. Just make sure your rice is clean and no small bug in it!
I was once unknowingly loose the shutter release socket's cover while shooting in a typhoon category 2. I got condensation built up on the top of the sensor. I know that because every photo turn out with foggy glow effect. I though it was a cool built-in effect but I just want a normal photo so I tried to find a way to turn it off for a while!
Another 3-4 times it was just too much water I guess. The autofocus always stop working first and pretty much similar to what you descried happen next if I still keep on shooting.
Before go out in the rain, check if you close every socket. Some time I just tape every socket with black tape. Check if you not lose the shutter release socket cover. Check every screw on the camera to make sure they are not loosened. Don't trust kit lens if the rain is heavy. And last, bring a few towers with you and keep wiping water off the camera and lens whenever you can.
While shooting, you better protect the camera as good as you can from the water. Don't forget, it is a weather sealed, but it is not a waterproof system. I shoot in heavy rain often, but the camera will get wet only when I shoot. I don't walk with camera and lens exposed to the rain, and try to dry it up as often as possible.
Hope your camera turn out OK.
