Originally posted by Not a Number Be sure to safely eject/unmount the card from your PC or Mac before removing the card from the reader.
The computer OS can also put hidden files and folders on the card which sometimes can cause problems. One quick solution for this is to set the read-only tab on the card (provided the card reader has a sensor for this) before putting the card in the reader.
For what it is worth I've never had a problem caused by Windows writing extraneous files to the card. But I always safely eject the card.
Thanks for the info...i'm sure I ejected one of the cards, can't swear to it on the 2nd. I know I didn't set the read-only tab on either card. Is there anyway to find these windows files on the sd card?
Thanks!
---------- Post added 08-20-21 at 05:56 PM ----------
Originally posted by MossyRocks It likely may have been that you didn't eject the cards nicely from windows, especially if they are new cards. Use the safely eject card option in Windows and format in camera is really the best way to go. If they are old well worn cards it may be that they are starting to fail but that usually takes lots of use as in 10s of thousands of pictures taken for modern cards. I've worn some out but that is after several years of doing astrophotography and I think I get about 60,000 shots on a pair of cards (write the same to both) before one in the pair starts having problems and then I just replace both cards with new ones. It is a lot cheaper than film..
These are both brand new cards that I've taken the pictures on so I doubt both would fail in the same way. If I can't find a solution I will reformat them..but I'm hoping I can figure out the issue first with some help! Thanks for your suggestions!
---------- Post added 08-20-21 at 05:57 PM ----------
Originally posted by brightseal How old and which brand are you using? Probably not a bad idea to use different SD cards.
Brand new cards (within the last 6 months)..both San Disk Extreme Plus 128 GB.
---------- Post added 08-20-21 at 06:03 PM ----------
Originally posted by AfterPentax Mark II If I were you I would try a third card, format it in camera, take a view pictures, transfer them to your computer, close the transfer program, use safe removal, and put it back in the camera. If it again says format the card have the K-70 replaced, because the camera is not working properly. Wonder what happens if you put SD 1 and SD 2 back in the cardreader and connect them to the PC. Can they be read on the computer or do you get a message that the card is unreadable?
When I can get a 3rd card I'll give your suggestion a try. I did try the cards back into the card reader and I can view the pictures on the card. When replaced into the camera (after safely ejecting of course) I still get the "format card" prompt.
Thanks for the suggestions!
---------- Post added 08-20-21 at 06:11 PM ----------
Originally posted by 35mmfilmfan I do the same as you, fill each card (or nearly), then archive it and replace it. I also set write protect as soon as I remove the card from the camera, then use Windows Explorer to copy the images to their destinations on my data drives. Never had the issue you describe - only associated problem has been replacing card in the camera (K3) without removing write-protect, at which point the camera politely reminds me.
I've never used the write protect on the cards but I will for sure going forward. I've never had this issue in any other camera so this has confused me a bit.
Thanks for your feedback!
---------- Post added 08-20-21 at 06:14 PM ----------
Originally posted by C_Jones I usually format my cards in the camera that I use prior to each use after unloading their images on my computer. As was said above, after moving images to the computer, the next step is to choose the Eject option on the computer, and choosing to remove the device being used (sd card reader for example). I always make sure the card is formatted in camera after use in a computer or any other device.
So you reformat a card each time? Do you do that to simply reuse the card or is there another reason like things getting corrupted on the cards? It seems like no one else is having my issue so I'll have to figure out my game plan asap!
Thank you!
