Originally posted by longbo Thanks. I've tried gently warming it with no luck. I'll try a bit more heat and see if that helps. I don't think a professional repair is realistic as eBay has these lenses starting at £60. I'm just hoping someone may know how to get it apart!
On my (Sears branded) copy, there are four screws at the upper end of the distance scale which bind it to the focus barrel. When those screws are loosened, the distance scale will drop down and the focus barrel can unscrew from the lower half of the lens.
Unless the barrel is stuck!
I'm not sure what to recommend other than more heat..?
The screws to loosen (orange circle) can be accessed without lifting up the rubber focus grip. But my lens had lacquer on the barrel under the grip. The lacquer was joining the distance scale and focus barrel at the seam at the top of the orange circle. I used acetone to dissolve it.
The right side pencil mark shows correct alignment for the distance scale and focus barrel. The "+" pencil mark was over the infinity line when the focus barrel separated from the lower part of the helicoid.
I believe it's typical for mirror lenses to be set to focus a bit past infinity.
My only task was to re-grease the helicoid so I didn't disassemble anything below the distance scale.
Good luck, longbo!
