08-26-2021, 06:43 PM   #1
K200D Aperture Issue
I bought a K200D off of Ebay recently and it works fine with my M lenses or an A lens in a manual aperture setting. When I shift to A the camera it reads the lens information (no F--) but always stops down to F22 regardless of camera settings. So everything underexposes naturally. I've tried cleaning the contacts as well as the conductive ring under the lens plate. I've reset the camera settings and tried new batteries with no effect. Any additional ideas or advice?
08-26-2021, 07:06 PM   #2
swanlefitte's Avatar
That sounds like a stuck soleniod in the aperture control. I wonder if the camera had it removed to to put in a newer camera as a replacement.
Does the flash pop up? If it doesn't both solenoids have probably been taken out.
08-26-2021, 07:27 PM   #3
ChristianRock's Avatar
QuoteOriginally posted by swanlefitte Quote
This is possible, and it would be a shame indeed... as it's a great camera.
But it's also worth it to try to clean the contacts, both on the lens and on the camera. It's happened before that by doing so these kinds of problems get fixed.
08-26-2021, 07:35 PM - 1 Like   #4
QuoteOriginally posted by scottike Quote
Test this way: (lens on A!)
Set the mode Dial to Av
select f22
and then step by step open up to whatever wide open is.
You can also look from the front into the lens:
If the lens stays always closed (f22) when you take a photo it is the solenoid.
Now, if this is the case, a previous owner must have changed the white Japan solenoid, which is in every K200D without exception against
the green China solenoid which was used from the K30 upwards.
Some people do this and file the green solenoid which makes it work for some time.
The pop-up flash works with the green China solenoid! Some K200D's had it inside when manufactured!
But you can pop it up only with batteries inside and switched ON. So careful if you disassemble it. Read about discharging the flash capacitor!
Read here:
A LITTLE BIT OF HISTORY: Development of the solenoid in Pentax cameras - PentaxForums.com
The white Japan-solenoid never fails this way. Well....ultra ultra rare exceptions could be.
It is easy to replace. No hidden screws, similar to this tutorial:
Manual solenoid replacement Pentax K30 / Discharge flash-condenser / Solenoid choice - PentaxForums.com
But I'd contact the seller first if not too late and solve it there.
08-27-2021, 06:33 AM   #5
The flash doesn't pop up either, so it seems likely both solenoids were harvested. I thought that might not have been the case since the aperture stopped down appropriately when not on "A". But it stays closed for all settings in Av, so it must be missing.
Thanks for your help. I'll see what I can do with the seller.
08-27-2021, 11:23 AM   #6
Not a Number's Avatar
You can always use it with screw mount lenses. Depends of if who ever opened up the camera did any collateral damage while removing the parts.
08-27-2021, 11:48 AM   #7
The lens is stopped down by the preselect aperture, so no solenoid in action.
You most likely paid with paypal. So you could open a case.
aperture, camera, k200d, lens, pentax help, photography, settings, troubleshooting
Lens w/o aperture ring + adaptor to M4/3 : effect of adjusting aperture on adaptor? timo Pentax SLR Lens Discussion 5 08-18-2021 04:03 PM
Auto Aperture FAQ - changing aperture using lenses without aperture ring angerdan Pentax Film SLR Discussion 9 08-06-2021 10:20 AM
Aperture block on K50...Finding legacy lenses with aperture rings give new life! PBRD Pentax SLR Lens Discussion 18 05-14-2021 06:55 PM
Aperture control problems with variable aperture lenses (with aperture rings) gtxSeries Troubleshooting and Beginner Help 3 09-13-2017 01:11 PM
Aperture 2.1 + K200D Import Issue drewdlephone Digital Processing, Software, and Printing 3 11-29-2008 12:56 PM
All times are GMT -7. The time now is 01:59 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
