Originally posted by UncleVanya
Sony had an issue where the ibis attachment points broke under stress and the sensor could move a corner out of the correct plane which clearly wasn’t bending but the magnitude of the alignment drift was higher in one corner.
That’s the kind of fault I am thinking about. On the problem shots I seen so far, it would appear the lower left front focuses relative to the rest of the frame. Often I have a framing element in lower left eg a close by tree or bush which can potentially obscure the issue so I will need to pixel peep to look at the more distant (infinity focus) composition elements near said framing elements to see if they are in focus or not. I will be spending more time working through the 4500 images I took over five weeks to see if I can identify when the issue first became apparent and if there is any obvious recurring usage situations. At this stage, tripod shots (IBIS off) look ok which is why I am pondering potential issues beyond the lens.
I want to be reasonably sure of whether it is lens or camera before I send anything off for repair, as based on prior experience, more optically complex issues get shipped off by the local importer to Japan for service. The K-1 and DFA28-105 are my work horses so don’t want to loose both for potentially three months or so. On the other hand, having items sent to Japan means they get worked on by Pentax’s own technicians which is confidence boosting in the quality of service.
Until the last few days I’ve never really though about how the sensor is held steady with high accuracy in the fore/aft z dimension while being able to move with very little friction in the x and y plane and also able to rotate to counteract roll.
I will report back once I’ve reviewed more images.
