Hello!
I noticed a strange behavior on my K-3 - a part of an image is noticeably softer than the the rest.
Long story short:
I've bought a DA 50-135 more than half a year ago and it turned out to be decentered - I noticed a consistent softness throughout the zoom range, which only affected one side - the left. The center was sharp, right side a bit less, but acceptable, and the dar to the left the worse it got. I send it to service where the supposedly changed 2nd lens group, did some calibration and sent it back to me after 2 moths. I tested it again and that day everything looked fine. Then my gear spent most of the time in a closet.
Now I recently acquired a DA 18-55 WR and this problems seems to be back. Before that however I finally took my Pentax out of the closet a few weeks ago I took some pictures. Later that day looking on them on my computer I noticed that the left side is much softer that the right, what got me. I was expecting delivery of the DA 18-55, so I thought I'll take them both to a "field test". My first field test was taking photos of a wall at a distance of ~10m, on tripod, self-timer, LV, 5 focus points (center + corners). Both of them showed no decentering issue (DA 18-55 was more uneven, but it's acceptable in its class). Then I took them to a park, when I had a chance to take photos where lenses' focus distance was set to exact or near infinity. Same story as above - tripod, self-timer, LV, and the results where the same - both seemed to achieve similar sharpness when comparing two opposite sides.
Things got strange when I took the camera out of the tripod and shot handheld. Then I noticed that a few photos had that kind of "de-centering" issue (both lenses). I think that the common ground for both lenses is that the IBIS was enabled in the photos, that were shot handheld, but it's not the case where every shot with IBIS ON was defected. There is a few days left for my DA 50-135 repair warranty, so I would like to know if that could be a body issue (particularly IBIS; Pentax K-3) or it's lenses'.
Currently I have a problem with taking a photo on command, that would show this issue. I took additional tests, but so far I have trouble to point out the deciding factor here.
Do anybody have any knowledge of this type of issues? Is there a way to accurately test it, so I can be sure where's the devil?
Any help would be appreciated.
