Program Mode for the K-1 (and some predecessors including older Pentax film cameras) is a mode which selects the best judged (by the camera) conditions of exposure based on set needs. There are at least three settings for Program mode which come to mind:
Motion Stopping - the camera will try to get the highest shutter speed possible while placing less importance on best aperture and ISO (if ISO is allowed to float).
Depth of Field - the camera will minimize the aperture to get the best DOF (the K-1 allows the minimization of DOF by using the largest aperture).
MTF (modulation transfer function) - this sound's complicated but it's not. The camera prioritizes the aperture which will provide the
sharpest image (based on information provided by the lens being used when available). Hence, you might find the aperture is always near f 6.3 when using a given lens because this is the sharpest lens opening for that lens.The latter mode assumes that a lens can report its best MTF to the camera which many recent lenses can. This is kind of like a "smart" Av mode with the camera selecting the aperture and varying it depending on the lens & focal length used (zoom lenses can have different best MTF points depending on zoom setting).
Program mode in Pentax cameras usually allowed the program setting to be manually overridden by the user through the use of adjustment dials. This allowed one to instantly drop into Av or Tv priority from the Program mode (and the "green button would return the camera to Program mode in later implementations). I use the MTF Program mode a lot because I like the best IQ, but there are times when I need high shutter speed or high DOF, and the adjustment dials get me there easily.
Auto Mode, on the other hand, will juggle things for what the camera thinks will provide the best compromise to get a good photo, not necessarily emphasizing any of the above priorities over another (good for newbies).
