Originally posted by BigMackCam On the K-S2, you want menu C2, option 7 - "Bulb (B) Mode Options" (same as on my K-3). Select that, and you should get a couple of options - I think they're called "Type1" and "Type2". The second one is the one you want
Thanks so much for this informatin (it is C1 though, but no big deal, smiles)....
I will give this a try tonight. How long do you guys/gals suggest to do this - from one button press to the next - ?
Also, I may give the other methods a try also. I see some options are that, perhaps, the camera only takes a pic if there is a movement (or brightness change) in the sky - ? And I read where there are another option or 2 more.... I think it falls under "interval" somehow....
Any comments on these, please do tell....
Regards,
Michael
